Question Running 1660ti fans at %100 speed
Jun 8, 2019
23
While playing PUBG my gpu temp goes up to 87c, on No Man's Sky it goes up to 82-83c. I think thats way too hot for Asus 1660ti oc. When i set my gpu fans to %100/4200rpm it reaches 78c max. My room temp is 32-33c. Is it ok to run my fans at %100 4-5 hours a day when playing graphic demanding games?
Btw my i5 9400f runs cooler than my gpu.
Jun 8, 2019
23
One intake fan and three exhaust? That's your problem. Not enough fresh cool air being pushed into the case to trade blows with all the heat.
Also, I assumed you were overclocking because you said OC for your GPU.
Should i switch to 3 intake and 1 exhaust?
Also i dont think the bad airflow is a problem since even when i take the side panel off the temperature doesnt change much only 1-2c lower
