JoshuaB123 :
Planning to run a dual loop in my CaseLabs TH10A for the new skylake motherboard and cpu when they release very soon in August-September, I have three 560mm radiatiors, each having four fans and 5 more for regular airflow. For fan controllers do I choose two Lamptron FC8s, two software controlled Corsair Commander Minis, or two Lamptron CW611 which will allow to me to control the D5 PWM pumps for the dual loops + fans. Thanks, any advice welcomed.
PCPartPicker - http://pcpartpicker.com/p/78ygcf
Fan controllers: I wouldn't get any of those tbh. First, my experience is, I don't care what they rate the controllers at, I have yet to see a lamptron controller that can handle a 20+ watt pump without overheating and crapping out, let alone two. Plus obviously you lose the PWM control. So I would suggest no matter what you do, hook those directly to the MB\PSU. Alternately, based on what you are spending, an Aquaero 6 wouldn't be out of line.
Fans: I mean, there is nothing wrong per say with the Corsair fans, they're perfectly fine for an amateur\budget build, but for something like this I suggest some real fans, either GTs (best if you can get them) or NB eloops, something that will push a good amount of air through a rad without sounding like a vacuum cleaner.
