I've got a Iiyama prolite B2888USHU-B1 that is connected via HDMI 2.0 cable to my 1060 6GB, however, the settings of the monitor only allow 1440p @60Hz or 4k @30Hz. Is there any way to set it to 4k @60Hz?
I believe the DP port on my 1060 may be damaged, but i do have a DVI port that is connected to a 2nd monitor at the moment. A possible solution might be to use a HDMI to DP/DVI converter? Or upscaling/downscaling?
