Running 5 monitors with a GTX 1080
Evan Shaffer
55
So, I've learned that the limit of screens on a GTX 1080 is 4 monitors. I have a triple monitor setup running at 1080p each, and configured with Nvidia Surround. Then I have a TV mounted above those monitors running at 1080p as well. These work fine together and won't cause any issues. However, I recently got an Oculus Rift. This counts as a 5th monitor, so whenever I want to use it, I need to disable my TV, then put on the Oculus. Otherwise, the Oculus simply won't power on and display.
This isn't too big a deal, since I won't be using my TV when I'm in the Rift. Only a slight inconvenience. But is there any way around this? I thought a simple fix would be to run the TV off of my Intel GPU, then my other monitors off the the 1080, but I haven't found a way to accomplish this or if it would even work. I've tried plugging the TV into the motherboard HDMI, but Windows doesn't detect it.
Besides possibly running it off the iGPU (I think there's a option in BIOS) if you have another PCIE slot on your motherboard you could try to find a cheap GPU that doesn't require additional power from the PSU and supports your HDTV resolution.
Thanks a lot! I just went into Bios and enabled the IGD option to run displays through the motherboard, installed the latest Intel graphics driver, and voila. 4 main monitors and no issues when putting on the Rift.
