Hi,
Ok so I took my comp apart to install the 960 Evo and while I had it open I cleaned the dust from my radiator and fans but when I put everything back together it started overheating. At idle I was in the range of 45-50c at stock clock, before I added the M.2 I was idling at 27-30c at 4.5ghz. I thought maybe I accidentally hit the tubes from the water cooler and messed up the paste from the block so I cleaned the paste off and added some new paste but the only paste I could get w/o having to order it was some stuff from Best Buy called TG-7.
So now I'm oc'd to 4.6ghz and I'm idling in the range of 35-40c which still seems a little hot compared to what i had it at before. My pump rpm is about 3150-3200 and my fans are at 2800
Am I ok or is this hot? Any ideas or comments are appreciated.
