Wireless Router: Cisco Linksys Wireless N300 (single channel)
Switch: Netgear GS605 5 port gigabit
Modem: Arris sb6141 (not a modem/wireless router combo)
Okay, so, I've been reading through multiple threads about running a router behind a switch and I'm not sure the answers I've seen are making sense.
Everyone seems to be saying that it won't work cause the ISP will only assign one IP address and so only 1 device will be able to connect at a time.
And yet, I have just hooked up my switch in front of my wireless router and not only does my home wireless network have internet but my desktop PC, which is connected directly to the switch also has internet.
Background: The reason I wanted to try this setup is because I currently have an older wireless N router and the ports on the back are NOT gigabit ports. As a result, my desktop PC cannot take full advantage of my internet package (110mbps download)...I'm only getting 90-95mbps download due to the limitations of my router's ports.
However, my switch has gigabit ports on it. So, I hooked up my switch directly to the modem, then hard wired my PC into the switch and presto, I am getting 114mbps download to my desktop. I then hooked my wireless router to another port in the switch and so far I'm not having any issues getting internet on both devices at the same time.
**End of Background**
So I guess I don't understand why everyone says that this setup won't work...it's working for me.
A couple more questions:
1.) Is there a way to keep the download speed of the ports on the switch while at the same time making everything run on my internal network from the router? As of right now, my PC is getting an IP address from the modem but my wireless devices are getting their IP addresses from the router and so they can't directly communicate.
2.) Am I looking at any serious security concerns running my desktop PC off of a switch that's connected directly to the modem rather than behind my router? I do run anti-virus and my Windows firewall is always on.
3.) The only downside to this setup that I'm noticing so far is that my wireless speeds have dropped from 40-50mbps down to around 15mbps. This is with the wireless router behind my switch. Is this result expected? If so, is there any way to get the wireless speeds back up to what they were before I added the switch in front of the router?
