HI There!
MY Specifications :
CPU : Intel Core i5 4590@3.3 GHZ
Memory : 8+2 GB Corsair 1600 Mhz
Motherboard : MSI B85-G41 PC Mate
HDD : Samsung HD502HI (500GB)
GPU : MSI GTX 760
PSU : Corsair VS650
Sound Card : Asus Xonar 5.1 DG
OS : Windows 7 Ultimate 64 Bit
So actually I'm going through a crashing issue of my system since I bought it, but earlier the crash was into BIOS. Later carried onto with Random crashes and now even crashes when the system is just idle. I've made a separate thread for that and haven't yet a solution to it but soon gonna update it as I'm gonna get some update.
Right so that thread is separate but related so I just mentioned.
Regarding this thread when I perform the CPU stress test with prime95 it kept going on and I left it overnight with the test running on. I woke up in the morning and the stress was still going on. I thought just to add a little more stress on my GPU side by side so I ran the GPU stress as well with Furmark. It started up very slow and found laggy distorted images in the GPU test. Soon within 2-4 minutes my system just got crashed.
Also I'm running the CPU stress test and the main window of CPU stress (where it displays all the passes and all) is disappeared itself but the stress test is still going on as my CPU usage is still 100%. I guess its going on in the background but is it also normal? I can't see that.
Then I ran the GPU stress separately for 1 hour no problems at all. Temperature maximum reached to 82 degrees. But when I combine both the stress test i.e. CPU + GPU my system gets crashed.
Question : Is it normal for my system (as the configuration stated above) to get crash when I try to run both the stress tests at the same time?? As separately both stress tests worked/performed with no errors.
Thank You!
MY Specifications :
GPU : MSI GTX 760
PSU : Corsair VS650
Thank You!
