It's time to upgrade my GPU and as I have Crysis 3 in my library, I want to get a card that will run it. I'm on a tight budget but I've seen a GT 730 2Gb GDDR5 that's well affordable at £55 ($90). However, I've seen info that says you need more than 2Gb to run Crysis 3, but I think that may be if you have multi monitors, super resolution and at ultra hi specs.
I've got an ASRock B85M Pro4 Mobo, Intel core i3-4130 CPU, 8Gb of G.Skill Ripjaws DDR3 RAM, W 7 64bit OS and HDD's for OS and games library. I use an LCD TV as my monitor, with 1360 x 768 resolution and I guess I'm on 720p format due to using the VGA socket at present, though I'm thinking to try 1080p as the TV has HDMI sockets.
I think that the GT 730 will run Crysis 3 on medium/high settings if I stick with 720p, but if I move up to 1080p I suspect it might only run it on low settings.
Does anyone know how well a GT 730 of the above spec will play Crysis 3?
Does anyone have any suggestions for an alternative GPU?
Thanks
Thanks
