Running HDMI audio only from pc to receiver
squee116
16
Okay, so here's my setup.
Asus Crosshair IV Formula
AMD 6870
Onkyo TX-sr606
Vizio 42" TV
So I have various HDMI inputs on my Onkyo receiver, which I have filled with my PC, my PS3, and my cable. The receiver has and HDMI out to my TV, so I can route all my video. The PS3 and the cable work flawlessly. But PC is a little wonky. I'm currently setup on my pc with a normal monitor besides the tv connection via receiver. This monitor is my main display and what I spend most of my time on. Usually, I just used my receiver for audio with a toslink cable, and ran an HDMI cable to the tv if I wanted to extend my display. However, I got the new onkyo receiver, and I switched the setup to run HDMI for audio and video through the receiver to the tv. Now, I can't get audio only from the HDMI hookup.
In order for me to get audio AT ALL from the hdmi hookup from my pc to receiver, I have to extend the display so that my tv would be included by my computer as a monitor, BUT I don't need my tv to be on. Otherwise, my ati audio device tells me it's not plugged in. This has me wondering... do I need a video signal sent through the HDMI cord for it to be detected by my receiver? Is there any way to get audio only, with the option of having the tv as an extended display, instead of it being mandatory?
It's enabled. The only problem is that it won't recognize the HDMI cord is even plugged in unless I have my monitor set to extending the display to the TV output on my receiver.
Attach the monitor to the AVR with a HDMI switch or buy a HDMI sound card and use a VGA to HDMI adapter to generate a dummy HDMI video signal for the sound card instead of a dummy extended monitor in Windows.
