Question Running LM 19.1 from USB stick (pendrive)
69Rixter
6
I've "installed"(not "live") LM 19.1 onto a 16Gb (2.0) PNY pendrive. Right off-the-bat, it has major lagging issues and somewhat to a lesser degree, freezing. Example: complete 'boot-up" takes about/around 10 mins to fully initiate.---from splash screen to full "home page" . After which, going to "net", again takes an inordinate amount of time. Once browser is "loaded", it can load pages almost immediately, (sometimes) but usually takes 3-5 mins. D/l times vary depending on their size, but there, often, it freezes and is extremely slow. This is the 3rd LM distro I've tried and the last 2 (LM 18.3 & 19.1) have operating issues that I've not been able to solve. I once had LM 17.3 and it operated beautifully. (yes...from a pendrive). So, I'd like to know if there's anyone here that is familiar with the LM O.S's and may have an idea of what I must do to eliminate the issues of lag and freeze. Truth is, I've asked around at other forums and am not getting any responses. Same w/ "net", nothing there, so far, is of help. Yes, this version of LM is fairly new, but I still don't believe it should have inherent problems like I'm experiencing! Would appreciate some good help/advice.
THANX:
:spamafote:
Rick
Saga Lout
I'm still on 17 but I can't see how difficulties like yours are likely to be caused by a new distro. All the varieties of Mint have worked straight out of the box.
Are you using the same stick you've used before and is it plugged into the same port on the same machine? USB 3.0 would be preferable.
Dave8671
576
94
I assume you are using Cinnamon GUI right? Whats your specs and the type of graphics card you have. Meanwhile take a look at the end of this page at:
One more thing if you use mint always update using the command line
apt install update
apt install upgrade
There is a bug still in LM update manager I been watching it for a year. If you use the above commands you will be fine.
"Solving freezes during the boot sequence"
https://linuxmint.com/rel_tessa_cinnamon.php
Play the videos to see this how to set this up.
