Running on 40MHz or 20MHz?
leolaikz
5
How do I know whether my laptops wifi card able to run on 802.11n with 40MHz? I have a D-link DSL-2750U, two Toshiba M840 with Atheros AR9485WB-EG and a HP Mini S110 with AW-NB041H. I would like to transfer large files but the speed is way too slow even with the wifi set to 40MHz. Please help. Thanks in advance.
Leo
I think that all of those adapters will work with 40MHz channels, but if you have a lot of 2.4GHz wireless around you, it won't work well, as it requires so much of the available N bandwidth. Download inSSIDer and run it on a laptop around your place to look at the other 2.4GHz networks by channel and signal strength.
But actually I don't really know how to interpret the software. Crossing over each = interfering? Should I take the readings nearby the router, or at the spot where I use my laptop? Thanks for helping.
I think the speed of the wifi degraded due to interference. I changed the channel to a less crowded one and all of my devices able to obtain 150Mbps. and from inSSIDer, i notice that only if I use 40MHz (Channel bonding), then I could achieve max rate of 300Mbps. But even with 40MHz set, the interference of neighbours' wifi make it impossible to get 300Mbps. Thanks for your advice.
