Greetings..
First of all I apologize if I posted this on the wrong section, I'm still new here...
I'll try to make this quick.. I'm in the process of replacing my old case fans inside my PC (which by the way, I asked one thing or two about it here some time ago, very helpful).. The PC had 3 of those fans and it took around half an hour to remove them (the screws were problematic). The new case fans I've ordered haven't arrived yet, so the PC is now sitting without any case fans (no big deal, I had no plans on using it anyway)..
But then, all of a sudden, I got this important 'job', and I need to download a large file from the internet, a 100 GB archive worth of files and whatnot. I calculated the time it would take to download the file, it would take around 23-hours-something to download the file (let's just round it up to full 24 hours). I only have that fanless PC that I can use to download the file, I have no other options.
The plan is, I'll just go ahead and turn on that PC, and download that file. But I'm worried though.. Is it safe to run the PC that long without any case fans?
The PC will do nothing but download the file in the background, so I guess the CPU won't be used much and won't go hot (the CPU still has its heatsink fans attached, and it functions properly no problem).
So, what do you say? Running a PC for 24 hours without case fans, do or don't?
