So I am basically aiming for a completely silent PC while I work but then for gaming it doesn’t matter as I wear headphones anyway. Using MSI Dragon center I am running my i7 9700K at 4.0 GHz on all cores and all fans ( two case fans and two radiator fans on my 240 mm AOI) set to zero RPM. I guess this means that the only cooling is coming from the pump pumping the water through the radiator. This gives me a CPU temp of about 35-40 degrees C at idle. If/when I need to do some more demanding work/gaming I change the profile to 4.8 GHz on all cores with fans at their normal speeds. So, my question is, if I am getting reasonably low temps with all fans off and a silent PC, is there any possible damage that I could do to my components? I am thinking that as long as my temps stay low, then it should be o.k?
