running ram sticks with same make and model but different versions in dual channel?
Muhammad_161
68
I have corsair vengeance lpx 8 gb 2400mhz ddr 4 ram module with cas and timing 16-16-16-39 and ver 5.3. I am planning to buy the same model with same cas and latency class but the one available has a version 3.21. will they work in dual channel ??? my motherboard is gigabyte h310m
Matt C
14
I think version numbers are done because they'll use different memory chips depending on supply availability for the same model. It *should* be all fine but you won't know until you use it.
