I am running Ubuntu 20.04.4 LTS inside Virtual Box 6.1. (32) on a Ryzen 2700X machine, 32GB of RAM, GTX 1080. The host system is running fine, no issue there.
Lately I have run into an issue where when I start the VM, it goes to the load/splash screen in "switch mode" (which is a full windowed screen at 1980x1440 4:3) will start to the desktop, then flashes a few times the end of which it defaults back to 800x600 resolution.
Due to the way the menus work, sometimes I can 'grab and move' the setting screen enough to both change resolution and hit the apply button. Sometimes not. Almost without fail I can power off the VM and start it again and it will be back to the larger resolution but don't always stay there.
I have been using the VM as a test bed of sorts so I can learn a bit about it in order to migrate some work machines to it. I have it physically loaded on one machine here (a 3rd gen Intel OptiPlex) and have no issue with it, and have loaded it on a small handful of other similar machines up to 4th gen with no similar issue.
Is this more likely a fault of Virtual Box, or something going on with the install? I absolutely have been monkeying around inside it trying to teach myself things in a way that is easy to wipe and reinstall, which I have more than once. This latest VM is current and up to date on the Ubuntu side.
What should I look into about this?
