First build and not too impressed with the cooling performance. The CPU is running not that much cooler then it did with an air cooled evo 212 lol. Any ideas is anything is wrong with this set up, I would like cooler temps for CPU. This is one loop with GPU and CPU combined. Under my usual heavy use GPU temps are around mid to low 30c while CPU is in in the 60-70c range
Dual 360 x 27 mm radiator
PR15 DDC pump
i7 9700k (not overclocked)
Asus ROG Maximus XI Hero
Corsair Vengance RGB PRO
EVGA 1080TI(not overclocked)
Samsung SSD 850 EVO 500GB
Toshiba NVMe 512BG
Fan:
TOP 3 BeQuiet 120mm(intake)
SIDE 3 Lian Li 120mm(exhaust)
BOTTOM 3 Lian Li 120mm(intake)
Don’t thing any other components are relevant
double triple checked the thermal paste on cpu , fan curve doesn’t have much effect on temps. Pump is running of the molex connector at full speed. The whole loop set is thermaltake’s c360 kit plus an additional 360 rad.
any help would be appreciated
PR15 DDC pump
Toshiba NVMe 512BG
Fan:
