G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Well seems running XP Repair didn't work, while going to a site recommended
here about AV programs I received an error message and after clicking the
don't send it closed down IE.. Reading an earlier post on my problem which
seems to concern Dell's 8400s it was suggested that I should disable Data
Execution Prevention, I found through Microsofts Support I can pick which
programs I can stop Data Execution Prevention from running so I obviously
picked Internet Explorer.. I hope this is the fix for I hate the thoughts of
doing a format and fresh install of XP, not so much the XP but reinstalling
all my programs, documents, settings and such... damn seems to take me a day
and half to get it all back to where it we like it.... below is the
instructions from Microsoft to make these changes.. Has anyone else had to
go this route??
1. Click Start, click Run, type sysdm.cpl, and then click OK.
2. Click the Advanced tab, click Performance, and then click Settings.
3. In Performance Options, click the Data Execution Prevention tab, and then
click Add.
4. In the Open dialog box, locate and then click the program.
5. Click Open, click Apply, and then click OK. When you are prompted to
restart your computer, click OK.
go this route??
click Add.
