Running XP with two hard drives
Bob
3,414
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have an old computer that I'm taking parts out of and I
want to install the hard drive into my newer computer,
which is running XP and has a 60gb hard drive. The hard
drive I want to move is 20gb and it's only about 2 years
old. It's a Maxtor and I think it runs at 7200 rpm.
Would this be a tough job to do and can I run the
computer with two hard drives on XP?
thanks
Jerry
1,812
Tough job - no.
Two hard drives - yes.
"Bob" <anonymous@discussions.microsoft.com> wrote in message
news:3e9001c42afa$f6df81d0$a401280a@phx.gbl...
> thanks
Bob
3,414
do you want to elaborate on your comment about two hard
drives??
>-----Original Message-----
>Tough job - no.
message
and I
hard
years
>> thanks
G
Guest
Guest
Maybe I misunderstood what you meant. I thought maybe
you meant it would be difficult to run two hard drives
with XP. Is that what you were saying or did you mean XP
could run with two hard drives with no problems?
>drives??
>>Tough job - no.
>message
>and I
>hard
>years
>>> thanks
G
Guest
Guest
He meant, XP could run with two hard drives with no problems?
XP can run alot more if you have more IDE Controllers to do it.
G
Guest
Guest
Just make sure the drive now in the new computer is set with
the jumpers as master and be sure to set the old drive as
slave. Also make sure that you use the correct screws to
mount the drives and connect the IDE and power cables.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
| thanks
G
Guest
Guest
I
>thanks
Yeah just make sure to make the 60gb hard drive the
master and the 20gb one a slave. If you dont know how to
do that on the back of the unit were you slot in the ide
cable and power cable is a 2 pin connecter which you need
to move to position under a master or a slave there
should be a diagram of the config on the hard drives top
face then power up your pc and it will work.
G
Guest
Guest
I ran it easily 4 with no problems - till I got some sense in my head.
"theo" <anonymous@discussions.microsoft.com> wrote in message
news:07342411-C5EF-484C-965A-B9D8D5AA4E41@microsoft.com...
