RX 480 heat problems
The MSI one will probably have the best cooler of the bunch. Everything I've seen about them mentioned the cooler being too strong if anything
Will there be any problems with the xfx or sapphire since they are cheaper? I read a lot of post and as usual there are bad and good things mentioned for both.
Heat and noise are closely linked. If you don't care about noise, you can always crank up the fans for a cooler card. As said above, at stock settings the MSI is probably the coolest. Why is getting the coolest card so important?
