The TDP on AMD says it's 150 watts, and on bencharks sites it would hit around 160 watts. Mine only draws 125 watts max when gaming. What's the problem?
The tool I use to find out my power draw is MSI Afterburner.
At first, I thought it was a problem with my power supply, so I bought a new one (upgraded from Thermaltake TR2 500W to EVGA Supernova 750 B2). But that didn't seem to solve the problem.
Increasing the power limit using MSI Afterburner didn't solve the problem either. And when I set the power limit to -20, I get the exact same (or negligibly worse) performance, but less power draw.
Overclocking the memory clock didn't seem to add more power draw whatsoever.
I've also tried to re-plug the 6+2 pin power cable. Nothing changed.
My GPU is Gigabyte RX 480 8GB G1 gaming. Is the design newer (like less TDP) or something? New drivers?
Or could it be bottleneck? I don't believe I'm being bottlenecked. My CPU is i5-6600k.
