H HumanWall Reputable May 31, 2016 40 0 4,540 Oct 7, 2016 #1 hey guys i have rx 480 nitro which has a blue led that i have no idea how to change i tried the button on top of the back of the card but it dosent let me select the color i want is there any software which allows me to change the color of the led
Solution SammChisnall Oct 7, 2016 You can change the LED colour through Sapphire's TriXX software found at the bottom of this page: http://www.sapphiretech.com/catapage_tech.asp?cataid=291&lang=eng
SammChisnall Distinguished Sep 12, 2012 531 0 19,360 Oct 7, 2016 Solution #2 You can change the LED colour through Sapphire's TriXX software found at the bottom of this page: http://www.sapphiretech.com/catapage_tech.asp?cataid=291&lang=eng Upvote 0 Downvote Solution
H HumanWall Reputable May 31, 2016 40 0 4,540 Oct 7, 2016 #3 SammChisnall : You can change the LED colour through Sapphire's TriXX software found at the bottom of this page: http://www.sapphiretech.com/catapage_tech.asp?cataid=291&lang=eng thank you very much <3 was searching for it for a couple of weeks now xD Upvote 0 Downvote
