So i just bought my RX 560 Sapphire Pulse 2GB OC, and installed the newest drivers.
The problem is, the video signal crashes everytime im playing SW:BF DLC maps (medium settings) or PUBG (lowest settings) after a couple of minutes playing. I can play any other game at a higher quality, or even play SW:BF no DLC maps just fine for hours without crashing, or bf4 high settings.
I installed MSI Afterburner to see GPU, CPU and RAM usage in mid-game. CPU and GPU are always maxed out to 100% usage, but temperatures lower than 55 degrees celsius, RAM is not even getting to 7gb.
Even though the CPU and GPU are maxed out, my games run smoothly without any stutter or anything.
Whenever the screen goes black, i can hear the game for a couple of secs,but my GPU fan goes wild and speeds up like a demon. The only way to get back into windows is turning off the computer.
*NOTE* im using a DVI-D to HDMI cable for the GPU xD
*NOTE* i dont run any other programs in the background, just for ts3 or discord
My SPECS:
CPU- INTEL PENTIUM G4400 3.3ghz
GPU- RX 560 Sapphire Pulse OC 2GB
PSU- EVGA 450w Bronze
RAM- 8GB ddr4 2133 Kingston
MOBO- Gigabyte H110M-H
OS- WINDOWS 10 64 bit
HELP PLS! THANK YOU!
My SPECS:
