[SOLVED] Rx 570 white led indicator
Sep 11, 2020
Hi, i have asus rx570 4gb strix. As i bought this gpu have white and red led indicator above the gpu connector. Default white led indicator is on when i powered my cpu. Sudden i see the white led is off even when i powered my gpu. Now the white led is off all the time. I worried about the indicators. Gpu is working fine. No problems at all with gpu. Need some advice. Thanks
The led died most probably. Not an issue though if the card works fine and is in warranty.
Reactions: Souvikr56
Latest posts
