[SOLVED] RX 570 with 8+6 pin power
zwtch_17
56
I just recently bought a RX 570 4GB with 8+6 power pins. Should I plug it all in? Or just the eight pins? Thank you.
D
Are you sure your RX 570 GPU requires both 8 and 6-PIN/PEG power connectors ? What's the exact make/brand and Model number of your GPU. Because when I searched this DATABASE, I couldn't find any RX 570 requiring 8+6-PIN Power connectors.
They either require a Single 6-PIN or a Single 8-PIN, unless I'm mistaken.
But in any case, if the card indeed requires 6 and 8 pin cables then you need to plug in BOTH of them. But what's the make and model number of your PSU, Power supply ?
EDIT: This Sapphire Model does require 1x 6-pin + 1x 8-pin. There might be other models as well though.
Sapphire NITRO+ RX...
Sapphire NITRO+ RX 570 Specs | TechPowerUp GPU Database
Those cards can run just fine with only the 8-pin connected. The 6-pin is optional. This does not apply to all cards, but it does on the RX 570.
*Edit: I know this was true in the past because I've run half a dozen or more RX 570/580 with only a single 8-pin for both gaming and mining. I'm pretty sure Sapphire's website stated it was optional, at least at one time. However, I can't seem to find the documentation for that now.
Yes, it appears that you are correct. I almost forgot that some RX 570/580 models did require 1x 6-pin + 1x 8-pin.
This Sapphire Model does require 1x 6-pin + 1x 8-pin. There might be other SKUs as well. Though, whether the 6-PIN is optional I'm not sure if SAPPHIRE and other brands still implement this requirement now as well.
FWIW, My RX 480 GPU MSI Armor just requires a single 8-PIN.
youve got a nitro+?
Anyway regardless all you need is the 8 pin.
Other models I can not address.... im assuming you have a sapphire nitro... they are amazing overclockers
if you only have the 8 pin forget it if you have to use an adapter forget it.
Mine was bunk and even with a 650 watt gold... it had no go beyond base clocks
you wont hurt your card by trying just the 8 pin, but it might not work and certainly do not overclock it
Are you sure your RX 570 GPU requires both 8 and 6-PIN/PEG power connectors? What's the exact make/brand and Model number of your GPU. Because when I searched this DATABASE, I couldn't find any RX 570 requiring 8+6-PIN Power connectors.
They either require a Single 6-PIN or a Single 8-PIN unless I'm mistaken.
But in any case, if the card requires 6 and 8-pin cables then you need to plug in BOTH of them. But what's the make and model number of your PSU, Power supply?
I'm sorry for my stupidity. Now I realize that I think the Powercolor RX 570 PCB base is for the RX 580 too. It's because I saw RX 570 pictures from above, not from the side. After some time of observation of the picture, I realized it only has an 8-pin connector port soldered like any other RX 570. Thank you for your information, sir.
this is the picture
