[SOLVED] RX 570 with my power supply?
Zaraki Zenken Besin
255
My power supply is "CoolerMaster Elite 600w Ver.3"
Im planning to buy the "Overclocked Edition MSI Armor Radeon™ RX 570 4GB GDDR5"
is it good enough? how much pin power supply pin does it need? is my psu have the required pin or watts or something?
lastly an outtopic question, once i have the rx 570, does it consume alot of electricity even if my just browsing facebook and playing old games or only when playing at high-end games?
Thank you tom'shardware community
That's a very low-end budget PSU. Not the very best in terms of efficiency/quality.
https://www.coolermaster.com/catalog/power-supplies/elite-series/elite-v3-230v-600w/ I won't advice using this for stressful Gaming sessions though.
There are 2 PCI-E 6+2 PIN CONNECTORS for any GPU, as evident from this pic. Though, the specs section says it has only ONE.
Which exact GPU model are you actually planning to buy ? Mention the exact Model number, or provide links.
The above link which I gave, clearly says the card requires a SINGLE 8-PIN cable. Check the SPECS page::
https://www.msi.com/Graphics-card/Radeon-RX-570-ARMOR-4G-OC/Specification
exactly this one.
btw my processor is i7-3770
base on the other comments. it seems i need to cancel my order of the GPU
i already have the psu, recently bought it last week and was about to order the GPU right now
use this: https://www.coolermaster.com/power-supply-calculator/ for seeing if ou have enough wattage.
you can see how many pins you have on you psu and how many pins the gpu needs in the specs list of your gpu.
