I have an asus strix Rx 580 8gb was tested using display port by the seller but when it arrived it doesnt work on my monitor.
I brought it to an IT tech and they tested it using the DVI and it works but unfortunately Display port and Hdmi doesnt.
The problem is, I dont have dvi port on my monitor. I know my hdmi port isnt broken because i used to use hdmi port with my previous graphic card which is gtx 750 ti.
Used some adapters like hdmi to vga still doesnt work i asked the tech to buy a DVI to hdmi to test as a last option.
Gpu was running on dvi only. Used ddu to clean then installed latest rx 580 driver using the techs monitor. After installation, rebooted pc and tried to use a direct hdmi and display port inti monitor still no signal.
DVI only works and my Monitor doesnt have any dvi port i used the techs monitor using dvi to update snd clean drivers.
Monitor is asus VP249QGR 1080p 144hz
