Question Rx 580 or pc problem
Jan 26, 2023
4
Gods of helping forum i summon thee
https://prnt.sc/GJcPwWlB9gqz
this is my configuration
I HAD 700w PSU and rx 570 before this,i gifted them to my brother whose parts died.
I also have a mining rig that worked perfectly, it had 6x rx 580 sapphire pulse 4gb, and 1200 chieftech PSU, since i dont mine anymore i decided to strip it and gift my brother some of mine older parts ( rx 570 and psu )
I had modified bios on GPU when i was mining , so i used winflash and restored the default GPU bios and placed RX 580 and chieftech PSU in my pc case and used DDU in safe mode to remove old drivers from rx 570, so i installed new drivers for rx 580 with factory reset, it all seemed well.
I was so dead wrong, my games started crashing, i thought it was a temperature problem at first because it usually crashed around 80c temp. But i placed fan on 100% in the MSI afterburner result was the same on 40c GPU. I tried earlier drivers, no luck, i tried fresh win 10, on a new HDD same thing, i tryed using a different RX 580 from Minner same resault. I cant figure out what the problem is, i sometimes still hear the game in the background when my monitor goes black and all PC fans start spinning. I am open to ANY suggestions cos am desperate at this point. Question everything that i did cos i lost my faith and might forgot something.
Fun stuff : https://prnt.sc/q47sEoZiLmU3 furmark all the way.... it passed.
https://prnt.sc/hKTHyb7sQYFU heaven .... maxed, I RLY RLY dont get it
If two GPU have the same issue. I'd assume it is a software issue. It'll probably be quicker to just clean install Windows then restore your backup. Than to try and isolate the issue.
If you have a spare drive. You could try a Windows install on that. Then see if you get the same issue.
Tested on 2 other pc-s, same results, so far it's solved by using afterburner if its on in the background without any settings or changes...nothing crashes... but that cant be permanent solution ...
Update, they work stable with old drivers and afterburner just INSTALLED not even on. few times i tried new drivers, my win goes into loop. and i got to revert :/
