ElectroG Jan 18, 2020 2 0 10 Jan 18, 2020 #1 If I play newer games my gpu fan goes up to max and than stop adding signal to the monitor. The max temperature it can reach is 60c don't know why the fan goes to the max. My psu is a Zeus 600w.
Solution drivinfast247 Jan 18, 2020 Get a new PSU. A high quality unit 600watts or higher. The best you can afford.
drivinfast247 Glorious May 29, 2018 7,845 1,646 47,940 Jan 18, 2020 Solution #2 Get a new PSU. A high quality unit 600watts or higher. The best you can afford. Upvote 0 Downvote Solution
ElectroG Jan 18, 2020 2 0 10 Jan 18, 2020 #3 drivinfast247 said: Get a new PSU. A high quality unit 600watts or higher. The best you can afford. Click to expand... Thanks a lot for your help. Upvote 0 Downvote
