A Anguspcish Prominent Aug 2, 2017 30 0 530 Aug 3, 2017 #1 i accidentally bought a low wattage psu and i want to know which card pulls less power the rx 580 or the gtx 1060 Psu is corsiar cx450m (black white label)
Solution Finstar Aug 3, 2017 Nvidia recommends a 400w psu for the gtx 1060 and AMD recommends 500w psu for the rx 580 It would also help if you told us what psu you have.
Finstar Honorable Sep 7, 2013 2,420 170 12,640 Aug 3, 2017 #2 That would be the gtx 1060 Upvote 0 Downvote
why_wolf Splendid Aug 28, 2015 3,532 26 26,940 Aug 3, 2017 #3 how low wattage? Nvidia cards are more power efficient than the AMDs. Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,231 3,301 112,240 Aug 3, 2017 #4 What exact psu and what's the rest of your pc spec? Don't want to go frying your whole rig due to an insufficient psu failing on you. Wattage rating on its own is fairly meaningless, plenty of low end units struggle to put out 1/2 their rated wattage. We need make and model. Upvote 0 Downvote
Finstar Honorable Sep 7, 2013 2,420 170 12,640 Aug 3, 2017 Solution #5 Nvidia recommends a 400w psu for the gtx 1060 and AMD recommends 500w psu for the rx 580 It would also help if you told us what psu you have. Upvote 0 Downvote Solution
A Anguspcish Prominent Aug 2, 2017 30 0 530 Aug 3, 2017 #6 sizzling : What exact psu and what's the rest of your pc spec? Don't want to go frying your whole rig due to an insufficient psu failing on you. Wattage rating on its own is fairly meaningless, plenty of low end units struggle to put out 1/2 their rated wattage. We need make and model. corsair cx 450m with the black and white label Upvote 0 Downvote
Finstar Honorable Sep 7, 2013 2,420 170 12,640 Aug 3, 2017 #7 Anguspcish : sizzling : What exact psu and what's the rest of your pc spec? Don't want to go frying your whole rig due to an insufficient psu failing on you. Wattage rating on its own is fairly meaningless, plenty of low end units struggle to put out 1/2 their rated wattage. We need make and model. corsair cx 450m with the black and white label That's a pretty good quality psu. I recommend you get the gtx 1060 since 450w can still be limiting to the rx 580 Upvote 0 Downvote
A Anguspcish Prominent Aug 2, 2017 30 0 530 Aug 3, 2017 #8 Finstar : Anguspcish : sizzling : What exact psu and what's the rest of your pc spec? Don't want to go frying your whole rig due to an insufficient psu failing on you. Wattage rating on its own is fairly meaningless, plenty of low end units struggle to put out 1/2 their rated wattage. We need make and model. corsair cx 450m with the black and white label That's a pretty good quality psu. I recommend you get the gtx 1060 since 450w can still be limiting to the rx 580 thanks i'll get a 1060 instead but could it run a overclocked card or a factory overclocked card Upvote 0 Downvote
Finstar Honorable Sep 7, 2013 2,420 170 12,640 Aug 3, 2017 #9 Anguspcish : Finstar : Anguspcish : sizzling : What exact psu and what's the rest of your pc spec? Don't want to go frying your whole rig due to an insufficient psu failing on you. Wattage rating on its own is fairly meaningless, plenty of low end units struggle to put out 1/2 their rated wattage. We need make and model. corsair cx 450m with the black and white label That's a pretty good quality psu. I recommend you get the gtx 1060 since 450w can still be limiting to the rx 580 thanks i'll get a 1060 instead but could it run a overclocked card or a factory overclocked card It'll run a factory overclocked card. Manual overclocking will depend on how much power your cpu draws. Upvote 0 Downvote
