RX 580 XFX (problem?)
Jan 14, 2019
7
Someone can help me? Installed the RX 580 8gb today and everytime I boot up the system this screen appears, mid blu and collored lines, the system Works Fine and no problems when I am gaming but this screen on boot scares me.
This screen is normal or not?
https://youtu.be/fYmS-lBUieE
Thx for all
I found the problem, when the option "Windows 8/8.1/10 features" in BIOS settings is enable the screen shows up, but when disable the computer boot perfectly with no strange screen, thx all for the help, solved!
MSI Z97 PC MATE
CORE I5 4460
16GB DDR3 1333 (4X4)
SSD 240GB SANDISK
2 HDS, 1TB AND 320GB
WiseCase ATX 500W
I completely remove the old drivers, and I install the latest drivers on the XFX site.
The screen shows up before starting windows.
OMG 🙁
Ur 580's works perfectly in games before failed? because I have no problems in games. Just the screen when power on the computer.
FYI, you're better off getting the latest drivers straight from AMD. Not that that is what's causing your issue, given that it happens before Windows starts booting it shouldn't matter what drivers you have installed.
I'd try clearing your CMOS.
