F FireRonin Reputable Sep 14, 2016 7 0 4,510 Dec 18, 2018 #1 These should work together, right? im about to buy it and wanted to double check. I've got a 600w 80+ PSU
Solution Dark Lord of Tech Dec 18, 2018 Yes they are compatible. As long as your PSU is decent and a legit 600w it will be fine.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,806 1,853 159,590 Dec 18, 2018 Solution #2 Yes they are compatible. As long as your PSU is decent and a legit 600w it will be fine. Upvote 0 Downvote Solution
