Question Rx 590 Nitro connection problem to psu
Dec 2, 2019
Just bought an rx590 .It has 1 6pin and 1 8 pin that need to be connected to the psu
My psu is coolermaster 620w.
It has 2 pci express slots (6pin).Right now i dont have any pci cable connected because my old card (r9 280) was conncted to the psu with a - y adapter (molex) to 6 pin- .The y adapter was conncted to one of the power cables of the psu.
So what do i do know .If i keep the 6 pin adaptor as it is and i buy a pci express 6 pin to 8 pin would it work?
Do i need 2 pci express 6 pin to 8 pin ?
I would really not buy another psu if that is possible
Here is the psu and the 2 pci express slots
https://www.e-shop.gr/psu-coolermaster-rs-620-realpower-m620-620w-p-PER.806617
Here is the adapter i bought
https://nuera.gr/shop/kalodio-antaptoras-trofodosias-pci-express-6-pin-se-pci-express-8-pin-goobay-4040849936357/?skr_prm=WyJhMWMxM2JmMi1iZGFjLTQ5OTctYTVkZi03MDdmZGZjN2NiMGUiLDE1NzUzMDkxMDc5NTUseyJhcHBfdHlwZSI6IndlYiIsInRhZ3MiOiIifV0
Ignore the greek language just see the photos.
Thanks in advance
You need a new power supply.
Using a molex-to-6-pin is generally dangerous, and you are lucky that you didn't wind up with a fire, burnt wires, or any kind of instability.
Using a 6-pin to 8-pin adapter is also dangerous, because the 6-pin is rated only for 75W, but an 8-pin connector on the video card will expect to be able to draw up to 150W from those wires.
See the link in my sig for recommendations on PSUs, though I realize that in Greece, you may not have the same kind of availability that's in the US.
Reactions: akadimos75
