Question RX 6900 XT TUF Heat Issue
SuCkDuBsTeP
105
Hello,
I just got RX 6900 XT TUF Gaming OC GPU, doesn't matter which game I play the gpu TEMPS go up to 70 Celsius. GPU gets really hot I can feel hot air coming out, is this normal at all? the Fans are on Auto mode.
I have the same card and it's very normal. If you want to further low temps, you need to undervolt OR even better, limit your fps to your monitor hz either via vsynch or via adrenalin software radeon chill (preferably to your monitor native refresh rate). Don't worry about it. Anything below 75 is considered cool on modern gpus. Older gpu tend to heat up even more. Some old amd cards easily reach 85 degrees.
