Question rx 6900xt usage drops and low mhz
Jan 13, 2022
13
System:
sapphire nitro rx6900xt
r75800x (watercooled nzxt aio)
x570 gaming edge wifi
corsair rm1000x PSU
32gb 3200mhz
Problem:
In fortnite my mhz are aalways rly low between 500 and 900mhz, ive reinstalled win10, drivers and all drivers r up to date, but the graphics card doesnt want to go higher than 1000mhz, help
What graphics settings and screen resolution are you using in the game?
[/QUOTESe
settings dont matter have same problem if high or low, diffrence is just that in high it drops from around 160 to 5 back to 90 just dropping and rising all the time and in low about 300 to 20 backt to 220 same as in high just with bigger drops. Screen res 1440p 144hz
System:
corsair rm1000x PSU
32gb 3200mhz
Problem:
TimeSPy: https://www.dropbox.com/s/rqbd72pzog7kepb/Screenshot 2022-01-15 224733.png?dl=0
UserBenchmarks:
CPU: AMD Ryzen 7 5800X - 105%
SSD: Samsung 970 Evo Plus NVMe PCIe M.2 500GB - 332.8%
HDD: Seagate Barracuda 2TB (2018) - 98.1%
HDD: WD Blue 2TB (2015) - 87.4%
RAM: Corsair Vengeance LPX DDR4 3200 C16 2x16GB - 97.4%
MBD: MSI MPG X570 GAMING EDGE WIFI (MS-7C37)
I don't see anything wrong here.
Your lower 6900 XT usage could just be your GPU waiting for frames from your CPU. Does your FPS get better, worse, or stay the same if you run your games at 1080p?
Its only Fortnite, all other games like cyberpunk, apex etc. run fine its only Fortnite that has problems
