[SOLVED] Rx power is too high
Jan 7, 2021
Hello,
I have an optical fibre internet connection of 300 Mbps download speed. But since one month I am getting only 6 to 10 mbps download speed. I logged in my modem admin page. Is every thing ok? I don't know whether I have privilege to ask this question in this forum. My modem's info as follows:
Connection Info
Connection StatusRegistered, authenticated.
MACB4:F9:49:09:55:FE
FEC CapYes
FEC Upstream StatusDisabled
FEC Downstream StatusDisabled
Triple ChurningDisabled
Laser Device Info
Tx Power1.272166 dBm
Rx Power-29.207807 dBm
Temperature33.750000 C
Voltage3.347200 V
Bias Current17.100000 mA
Link performance statistics
Bytes Sent858183253
Bytes Received983663856
Packets Sent772703
Packets Received1012301
Unicast Packets Sent766220
Unicast Packets Received1009127
Multicast Packets Sent6370
Multicast Packets Received3172
Broadcast Packets Sent113
Broadcast Packets Received2
Fec Errors0
Hec Errors0
Packets Dropped0
Pause P{ackets Sent0
Pause Packets Received0
Warnning
EPON LOS
You should contact your ISP first, they can test at their end, if they say it's fine then start looking at modem, router,cables, connections.
Nobody bent that optics cable in half did they?
I have contacted the ISP, one of them told me that the Rx power is bad it should be -14 dBm to -22 dBm and other one told me that -28 dBm also good.
