Ryen 5 2600 build(need help)
endritgurgule
Proper
Aug 27, 2018
89
So, I’ve been researching for quite some bit and I came up with a build, but I wanted to have some different thoughts from other people. I would appreciate if anyone could put up a parts list with the r5 2600 in a 950€ budget(AMD gpu would be nice since a g sync monitor doesn’t fit my budget)
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor (€159.00 @ Mindfactory)
Motherboard: Asus - TUF B450-PLUS GAMING ATX AM4 Motherboard (€109.90 @ Caseking)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory (€154.90 @ Amazon Deutschland)
Storage: Samsung - 860 Evo 250GB M.2-2280 Solid State Drive (€63.48 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (€57.88 @ Amazon Deutschland)
Video Card: Asus - Radeon RX 580 4GB Dual Video Card (€223.89 @ Amazon Deutschland)
Case: Fractal Design - Focus G ATX Mid Tower Case (€42.99 @ Amazon Deutschland)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply (€85.99 @ Amazon Deutschland)
Total: €898.03
Generated by PCPartPicker 2018-10-14 22:00 CEST+0200
If you wish to reply, click "Reply to xxxx" on the text next to the buttons at the lower right of every post, which will quote the post and allow you to reply, OR click in the box at the bottom that says "Your answer" right above it then click Submit your answer at the lower right.
That depends on a lot of factors. The biggest factor will be what memory you get. Those modules PROBABLY will run at 3200mhz, but it will also depend on whether or not you overclock the CPU to bolster the memory controller and if you have the latest bios installed.
The single most beneficial thing you can do is get memory with Samsung B-die memory chips, which those are not. They are however significantly less expensive most the time since they are Samsung E-die.
If you want the best chance of achieving that speed, I'd find and purchase modules, preferably G.Skill Trident Z or Corsair Dominator modules, that DO use the Samsung B-die, and you can find part numbers for kits that do use them here. You'll have to do the work to actually find where they are for sale in your country.
https://www.overclock.net/forum/18051-memory/1627555-ryzen-memory-ic-collection-thread.html
Did some slight modifications and the price came 5€ over budget and it’s no biggie how’d you like it
[PCPartPicker part list]
(https://de.pcpartpicker.com/list/bWKhBb) / [Price breakdown by merchant](https://de.pcpartpicker.com/list/bWKhBb/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 5 2600 3.4GHz 6-Core Processor](https://de.pcpartpicker.com/product/jLF48d/amd-ryzen-5-2600-34ghz-6-core-processor-yd2600bbafbox) | €159.00 @ Mindfactory
**Motherboard** | [MSI - B450 TOMAHAWK ATX AM4 Motherboard](https://de.pcpartpicker.com/product/Hy97YJ/msi-b450-tomahawk-atx-am4-motherboard-b450-tomahawk) | €112.80 @ Alza
**Memory** | [G.Skill - Flare X Series 16GB (2 x 8GB) DDR4-3200 Memory](https://de.pcpartpicker.com/product/wX7CmG/gskill-flare-x-series-16gb-2-x-8gb-ddr4-3200-memory-f4-3200c14d-16gfx) | €214.90 @ Amazon Deutschland
**Storage** | [Crucial - MX500 500GB 2.5" Solid State Drive](https://de.pcpartpicker.com/product/ft8j4D/crucial-mx500-500gb-25-solid-state-drive-ct500mx500ssd1) | €80.24 @ Amazon Deutschland
**Video Card** | [Asus - Radeon RX 580 4GB Dual Video Card](https://de.pcpartpicker.com/product/XYDzK8/asus-radeon-rx-580-4gb-dual-video-card-dual-rx580-o4g) | €223.89 @ Amazon Deutschland
**Case** | [Fractal Design - Meshify C Dark TG ATX Mid Tower Case](https://de.pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg) | €84.90 @ Amazon Deutschland
**Power Supply** | [SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply](https://de.pcpartpicker.com/product/WrNypg/seasonic-focus-plus-gold-650w-80-gold-certified-fully-modular-atx-power-supply-ssr-650fx) | €85.99 @ Amazon Deutschland
| *Prices include shipping, taxes, rebates, and discounts* |
| **Total** | **€961.72**
| Generated by [PCPartPicker](https://pcpartpicker.com) 2018-10-14 22:26 CEST+0200 |
ALWAYS click the bbcode option when posting your build here. Like this.
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard (€112.80 @ Alza)
Memory: G.Skill - Flare X Series 16GB (2 x 8GB) DDR4-3200 Memory (€214.90 @ Amazon Deutschland)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive (€80.24 @ Amazon Deutschland)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case (€84.90 @ Amazon Deutschland)
Total: €961.72
Generated by PCPartPicker 2018-10-14 23:28 CEST+0200
Looks good, except the MSI motherboard. And that is just my personal preference, but myself and a lot of other people here have been seeing a marked increase in the number of problems with MSI motherboards, much like the problems they used to have when there were substantial quality control issues in the motherboard manufacturing side of things years back at MSI.
I would recommend sticking to ASUS or ASRock. Even Gigabyte although I've become jaded with Gigabyte the last few gens as it seems they too have dropped some quality and features from even their best boards.
Yeah I’ve seen quite some issues with msi mobos but since I saw very good reviews on the tomahawk one I thought I’d go for it. Well I’ll take your word on it.Asus is indeed one of the more trust worthy brands out there so I’ll go with that one
