Question Ryzen 1200 is stuck running at 0.53mhz
May 17, 2019
5
Hello ..
I using ryzen 1200 with msi pro a320 pro VD/s mother.
Psu 400 watt with one 4 pin connector .but
on my MOTHER BOARD is a 8-pin CPU connector
Ram 8 GB Corsair 2400 mhz..
Gpu gt710 2 GB..
I've noticed my Ryzen 3 1200 is stuck running at 0.53mhz regardless of what load I put on it. .
I just installed a win10 64bit and updated the bios and drivers.
can someone tell me .. THIS PROBLEM IS RELATED TO MY PSU. Because I am using 4 pin connector !
hftvhftv
Herald
May 26, 2014
640
63
11,090
22
Hello ..
Gpu gt710 2 GB..
Try putting the 4 pin connector in the opposite 4 pins on your 8 pin CPU connector. Don't force it if it doesn't fit.
May 17, 2019
5
What cooler are you using? Also what are your temps at?
I using stock cooler.. and
Could be you need to update the bios and enable performance mode in windows.
I already did.
If I restart the pc. It will become Normal cpu performance will increase and speed also increases..and sometimes when I turn it on it doesn't boot at first time ..I have to unplug the power cord several time ..
5
you need another psu to be able to power up board and cpu .
That might be a problem with PSU, but check your settings in BIOS. Try manually OCing to the stock 3.1ghz, that may fix it.
but if i OC THE CPU .IT WILL VOID MY WARRANTY
the board cpu does not receive all power it need so yes cpu could not be running at full speed .
But when I restart the pc..
It will work normally ..
85
6
35
You won't be OCing it, you'll be setting it to its base clock. This will NOT void the warranty, provided you don't change any voltage or other settings in BIOS.
