ryzen 1300x 4 pin or 8 pin connector
lee47
23
hello
i have ryzen 1300x and msi a320 m pro-vds motherboard. mother board has 8 pin connector i have only use single four pin connector. pc is running fine. should i connect the other 4 pin?. psu is antec vp 550p. sorry for my bad english. thanks
you'll probably get away with it, given that the board can cope with OCing the high end of the range of processors, that's when the +4 will come into use.
Yes you should.
lee47
23
will there be any problem if i connect 4 pin now? also does it make any difference in performance, temp etc? thanks
