I recently purchased a Ryzen 5 1600x (no overclocking yet) And I was curious to the max temperature this CPU can function at before shutting down the PC. Currently using a DEEPCOOL GAMMAXX 400 CPU Cooler which is an inexpensive air cooling unit. Plans for liquid cooling soon just wanted to put something on top of the Ryzen to cool it. Idles at about 35-40c and I've seen it anywhere from 50-65c under a gaming load. I also notice jumps in temperature up to 10c for a second or so then a gradual decrease back to where it was. Thermal paste application was applied as usual. I did strip a screw on one of the am4 brackets on my new mobo thinking I needed to take the thing off to install the cooler, The cooling unit is holding very tightly with 3 of the 4 screws in place on the brackets it's attached to. Not sure if that would affect temps. Any insight appreciated.
