Ryzen 1700 ram speed issues
nhaseven
Hi
i have the Ryzen 7 1700 coupled with MSI x370 xpower gaming titanium mobo and corsair Dominator platinum 3200 mhz with part number ending with 16. Two pieces 2 x 8gb.
Ram speeds are decreased to 2133 mhz automatically or else no boot!
Plus windows 10 pro x64 recognized 16 gb ram but usable only little under 8gb.
Kindly advice how to resolve both the reserved ram and the speeds.
I have the MSI 1080 graphics card
Thanks
Well test the ram chips 1 chip at a time with memtest86 and see if you get any errors. If you don't then try both at the same time. If you still don't get any errors then contact the ram manufacturer and ask them if they have any advice. If they don't then you RMA the ram and get a replacement set.
