I am having issues with my PC shutting off while trying to render in a larger 4K and up format.
I built this PC specifically for rendering, but somehow I am overheating.
I have a blower style Cooler, Cryorig H7.
Do you think getting an AIO with a radiator will resolve the issue? I have money to throw at the problem, but I need to resolve the problem once and for all....
It only happens on longer renders at higher quality settings, but when it does it just starts to rise and never stops until the PC shuts down from overheating protection.
I have tried to use the ASUS AI suite to optimize my setup and I have also tried to turn it down from a 3.8 to 3.4 and then back up to 3.7 on CPU frequency.
The system has a 1080TI so shouldn't it be handing off the duties of rendering to the GPU? Only my CPU temp shoots up while rendering.
I have just switched to Adobe Pro CC 2018 which I can't seem to find the setting to ensure I am rendering from GPU, but I am almost certain I am.
Does anyone have any recommendations or help? Should I change some settings in Premiere? Do you think my cooler is the issue?
Any advice will help!!
Here is a video of my temps as I render shooting thru the roof. I cancelled the render at 79 degrees which is just before my PC usually shuts off at about 80-81 degrees.
https://youtu.be/iA7GxqicKkk
OS Name Microsoft Windows 10 Pro
Version 10.0.15063 Build 15063
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name HUMANITIESDEMIS
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor AMD Ryzen 7 1700X Eight-Core Processor, 3775 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0902, 9/8/2017
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume5
Locale United States
Hardware Abstraction Layer Version = "10.0.15063.502"
User Name HUMANITIESDEMIS\Gumba
Time Zone Central Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 20.8 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 24.7 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
