I just bought an 1800x paired with an h100i v2 and it's idling in BIOS (with BIOS updated - x370 Taichi 3.00) at mid 50s. With some browsing it goes from 50-60c. The voltage randomly bumps to 1.4 occasionally for a split second on Ryzen Master. Anyways, I read an article saying that there is a +20 differential offset for the 1700x and 1800x so not sure if that's really a thing anymore since those articles were March.
1. If the whole offset thing is a thing, is that something that exists with bios updated? I've been using core temp and ryzen master to read temps. Ryzen Master is always 50-60c while CoreTemp reads 40-50c (then bios around 50).
2. I am running at 32gb of ram at 3200mhz using the XMP Profile provided. Is it better to overclock manually or use XMP profile? Not sure which one I benefit from more.
3. Is is possible that my fans were placed the opposite direction on my h100i v2 causing less cooling? I have my radiator on top (phanteks pro m case) and I couldn't tell how to place my fans with no direction showing. I want them facing up against the radiator but I can't tell... sorry I know I'm a newb lol.
4. I never installed my drivers for my mobo but nothing is with the yellow caution sign in device manager. Is it really necessary to install mobo drivers? I'm not sure if that would fix my temp issues but just curious if I really have to.
My setup is for editing 4K footage on the GH5 and gaming on the side. Ran Premiere and it seems to be smooth during playback. I've played a few games of Overwatch and everything seemed to run really smooth and temps weren't too crazy but fans did get loud. I've never owned an AIO though so it might've SEEMED loud to me. Hopefully I'm panicking for no reason...
Any help appreciated!
