I am running the following system,
Ryzen Threadripper 1950x
MSI MEG X399 Creation
Corsair RM750x
NZXT Kraken X73
GSkill Trident Z RGB 16 GB 3200 MHz
Zotac GTX 1080 Ti Amp Extreme
My system was running fine for 1 year, but few months back suddenly started to post 00 after running for 30 minutes to 1 hour. I was running a Thermaltake Toughpower 850W Gold PSU back then. I thought the psu was faulty, and changed it to the Corsair one above a few weeks back. But, the problem was not solved. I was also using an Enermax Liqtech TR4 II OC, and thought that the issue was due to thermal throttling because the AIO pump had failed (common issue for Enermax TR4 AIOs). So, I changed it to an NZXT Kraken X73 today. Still, the CPU CCD temps are close to 60 degrees in idle (although the package temperature is around 30 degrees - as shown in Open Hardware Monitor).
Are these temperatures normal? If not, what could be the problem... since, clearly the cooler's not an issue.
Corsair RM750x
NZXT Kraken X73
