Ryzen 2200g doesn't work as display output! HELP!
RedHood_12
Commendable
Jan 24, 2017
Hello,
I have a problem, I just built a basic desktop PC, it doesn't have a GPU.
When I finished building it and plugged in my HDMI cable and turned it on but nothing displayed on my monitor and it still turned on all the fans are spinning. I need some help.
Specs:
- Ryzen 3 2200G
- MSI A320M Pro
- 8GB RAM
- 1Tb HHD
THANKS
Did you leave it on for a while? The initial startup sometimes takes awhile before the iGPU is identified in BIOS and enabled. Maybe 30 seconds on one I had recently.
