Question Ryzen 2600 16gb 2933MHz OR intel i5 9400f 16Gb 2666MHz
Milan_24
Commendable
Mar 15, 2017
6
With these exact specs wich is the better pc with an rtx 2060 super?
The intel cpu is paired with a gigabyte b360 dsh3 motherboard wich i believe only supports up to 2666mhz. The Ryzen 2600 is paired with a b450 motherboard, wich i believe goes up to 2933mhz. Both are prebuilt pc's that come with 3000mhz 16gb ddr4 ram.
They both come with a goof cooler and i know the 2600 supports overclocking. I've seen the 9400 has better avg fps and the 2600 has better 1% lows, source: unboxed hardware ( sorry if this is against advertising rules i'm new).
My question is at what speeds will the ram run and wich pc will be better.
