Question Ryzen 2600 heat and edc problem
Jul 10, 2019
9
I've been using the Ryzen 2600 since July and I more than satisfied. However I have been using the stock cooler because I want to buy an aio cooler (Corsair i115 platinum or something like that). Yesterday I changed my case and I also changed my cpu coolers fan curve because it was really loud. I changed it to something ok in my opinion (because I want it to be quiet) and then I opened Ryzen Master to see the temperature (keep in mind that I changed the thermal paste from the stock amd to arctic mx-4 because I had it and I thought it was better). Today I started playing and the fan was really loud, not only did the fan curve reset but when I changed it again the cpu ran really hot 80 C while playing and 60 idle . Also my power supple is really loud, the fan is running always and the cpu in ryzen master for some reason is always on 86% ish out of the 90A for the EDC section. Also the CPU is always turboing. What do I do is there a problem??
P.S. I changed the CPU fan curve from APP Center which is a gigabyte program and from the bios of a Gigabyte B450m pro wifi i whic is running a bios form 25/1/2019
Dec 30, 2019
50
Try and test if the CPU is over boosting by setting a fixed voltage and fixed clock and testing the temps and tell us the temps.
Jul 10, 2019
9
the cpu is staying at 3800 mhz on all cores when playing games and the edc is on 99% which is normal, however when not doing anything the cpu is still turboing sometimes.Like core 1 will be at 3700 and then 2 will be at 3400 and then the other ones do the same
