Upgraded to Ryzen 2600 non X first thing i noticed was Temps above 90 Degrees the room temps around 25 Degree
I paired it with old Fury x 2133
Idle temps are around 58 Degs when at 3.9 Ghz but when i used OC genie 4
The mobo downclocks the CPU to 3.85 The temps are around 38 idle but max above 90
kindly help i tried HW monitor and Ryzen master both no luck there
also the CPU voltage is 1.22V
https://drive.google.com/open?id=1TynHqao0FLMpNL6tw3yMeLWzE56Kzym-
