Question RYZEN 2600 STOCK COOLER OVERHEATING!
Sep 18, 2020
4
Hii!!!!!!
My Ryzen 5 2600 i bought last week.
SPECS:
Case: Keytech t3000
MBoard: Aorus b40 elite
Procs: Ryzen 5 2600 (Inplay heatsink)
Ram: 1x8 ramsta 2600Mhz
Gpu: Msi Ventus 1050 oc
PSU: 500 +80 vortex
Storage: 215ssd, 500 hdd
Cooling: 1 rear, 2 top, 1 front
PS. The Heatsink i have is not from the Ryzen stock, because the store i brought from gave me the generic inplay heatsink.
The problem is -----
Idle - 50C
Youtube or Browsing - 60C
Offline Games 80C - 85C
Right now installing GTAV 90C
Valorant or LOL 90C
All the temp check i run is all accurate and the stress test is also accurate, the max i got is 100. I read all the solution u got with the thermal paste. Yes i remove the plastic before using it.
Should i buy Cpu Heatsink ing Gammaxx 400ex? It would decrease my temp if i buy it????
Thanks!!!
jadenwoolworth
Commendable
Sep 24, 2017
47
8
1,545
I run a ryzen 5 3600 on a 120 mm water cooler. It cost me around 50$. Depending on your budget and your preference to how loud your pc or what you want it to look like, this is all you. Just MAKE SURE in the specs of the cooler it has a TDP of 65 Watts. I like to go much higher and you probably can.
If you want water cooling go for the water cooler I linked. That's the best deal right now.
A 240 mm water cooler on sale: https://www.newegg.com/cooler-master-masterliquid-240-lite-liquid-cooling-system/p/N82E16835103252?Item=N82E16835103252&Description=water cooler&cm_re=water_cooler-_-35-103-252-_-Product
take your pick of quiet air coolers: https://www.newegg.com/p/pl?d=bequiet+cpu+cooler+am4&Order=1
If you'd like to research coolers yourself just make sure the one you choose is an AM4 socket
Reactions: neilllll
