Question ryzen 2700 may be running too hot
C0v3r
Great
Jun 9, 2019
137
4
85
i got a ryzen 2700 and an nzxt kraken 62 rev 2 along with one of the best noctua oc thermal paste i cant remember the name. but anyways i am at 4.0 ghz on all cores at 1.375 volts and i run cinebench and hit a max of 70c for a second with an average between 66c and 69c is this normal.
Temps should be lower, are you sure cooler is installed and running right, is pump running at full speed ?
C0v3r
Great
Jun 9, 2019
137
4
85
Update forget the last two posts i fixed the fan speen to 80 percent and it turns out the fans werent on then i ran cinebench and got a temp at max of 62 with an average of 61. But heres the weird part i got a lower score than my other teat 2 days ago at 4 ghz when i got 4k in cinebench r20. Now i only got 3600 wverything is the same so whh did it change so much
