[SOLVED] Ryzen 2700X High Temps
SubaruWRX244
513
Hello! So I got my GTX 1080 back from the RMA dept but i thought I'd ask you guys about my CPU temps . So I was playing BF1 on the 2700X with the Asus Ryuo 240MM AIO. Riva Turner was stating my processor temps as high as 83C and HwMonitor said 75C. I also noticed that the max clock was 4.9GHZ? This seems really high.
I have the AIO plugged into the CPU_Fan . Should I connect to AIO_Pump?
No, radiator fans should go to CPU_FAN, that's what it's for. Most MBs will complain or shut down if fans are not working on that header.
